I'm trying to create a custom rule for sequence analyzer. My goal is to check the step run mode (skip, normal...) and step tracing setting (disable or enable).
I took a look to the example provided with TestStand : http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/analyzer/
The CVI example is what I need except that I don't need NumberOfLocals properties of the locals variables, but the run mode property of the step, and I'm not able to get it
Does someone can help me to get step properties in CVI code ?
Thank you for your help !
Best regards.
Jules.
