Custom CSV Report
I need to create custom CSV report (actually txt file). The report needs to have header and body. All informations are stored in form of columns. For each measurement step new column must be added to the body. Additionally header will need to store first failed step name from the body.
Example:
UUT SN, Machine Name, First Fail, Step 1, Step 2, Step 3
xxx, yyy, Step 2, pass, fail, pass
Currently I'm lost in process model file and NI articles. I don't know which path should I take: modify Report Entry Callback or modify ReportGen_txt.seq, or maybe something else?
I would be grateful for any guidance on how to approach the topic. I have never customized any report.
Thanks in advance 🙂
Michał Bieńkowski
CLA, CTA, CPI
(5,075 Views)
A few questions.
For every test run, do you just append the results to the current file with the new UUT SN?
Or is this a batch run and you're grouping everything in the batch?
Is this report in addition to another report that might contain more data for your tests?
My first thought is that you should modify ReportGen_txt so that you can get exactly what you want.
Some options:
1. Modify ReportGen_txt, but I'm not sure if you're running other sequences on your system that may not want this same format.
2. If you're producing another report already, parse that file in PostUUT.
3. Modify the TestReport callback and use MainSequenceResults to get the data you want for your report.
Pulido Technologies LLC
(5,073 Views)
I'm using batch model and I need seperate file for each tested UUT.
I need only my custom reports.
How hard it would be to create my own ReportGen_custom secuence?
Michał Bieńkowski
CLA, CTA, CPI
(5,055 Views)
Modifying reportgen_txt.seq is not something for novice TestStand users, but it's definitely doable.  The default report generation covers a lot of possible step options (looping, additional results, multiple numerics, etc.) that sometimes can be missed when customizing.  In your specific case, it does sound like customizing reportgen_txt.seq is the most efficient option here.
(5,039 Views)
Accepted by topic author bienieck
Hi Michal,
the Simple Text Report plugin would be a good starting point. You can find the installation instructions here:
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/modelplugin/
Regards
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(5,007 Views)
