02-23-2010 07:28 AM
When I want to build a deployment package, I have this in the log window :
Warning: This problem will cause an error when building a deployable image or an installer. The following file(s) were not found:
DLL_AFDX.prj in step 'Init AFDX Board', sequence 'Init AFDX', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\SvTB Tools\AFDX Tool.seq'
DLL_AFDX.c in step 'Init AFDX Board', sequence 'Init AFDX', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\SvTB Tools\AFDX Tool.seq'
In my AFDX Tool.seq I call a function within a DLL (DLL_AFDX.DLL), the DLL_AFDX.DLL is in the workspace. I do not understand why TestStand deployer warns on DLL_AFDX.prj and DLL_AFDX.c. What can I do to remove this warning ?
Thanks.
02-25-2010 04:35 AM
Hi sfl,
How do you call your dll? Do you use a relative path or an absolute one?
Could you attach us a small example which reproduce your issue?
Best Regards.
Romain D.
National Instruments France
02-26-2010 01:43 AM
I use relative path.
I notice that I have no problem with an other DLL. The DLL with wich I have a problem is a DLL wich includes an other DLL (labwindows).
02-26-2010 11:49 AM - edited 02-26-2010 11:50 AM
sfi,
Can you check if "source code files" has been specified for the step, which calls DLL_AFDX.DLL.
The warning can be removed by either providing the files specified in the step or clearing out the "Source File" and the "CVI Project"specified in the step.
Anand Jain
03-01-2010 03:00 AM
Could you please tell me how can I check if "source code files" has been specified ? I do not want to provide the files specified but how can I clear out the "Source File" and the "CVI Project" in the step ?
Thanks a lot.
03-02-2010 01:31 AM - edited 03-02-2010 01:32 AM
Sfl,
Depending on the version of TS you are using, you might have to refer to different documents.
In TS 4.1.1 or earlier - please refer to section - "Source Code Buttons" in page 2-3 of the "UsingLabWindowsCVIwithTestStand.pdf"
In TS 4.2 or later - please refer to section - "Source Code Buttons" in page 11-3 of the "UsingLabVIEWLabWindowsCVIwithTestStand.pdf"
Anand Jain
03-02-2010 05:12 AM
Ok, thansk a lot, the warnings have disapeared.
Nevertheless, I have another type of warning to resolve :
Warning: You may need to add any sequence file(s) referenced by the following expression(s):
"reportgen_" + Parameters.ReportOptions.Format + ".seq" in step 'Initialize the On-The-Fly Report Generator Object', sequence 'Configure Post Result Callbacks', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Cfg\TestStandModels\ModelSupport.seq'
"reportgen_" + RunState.Root.Locals.ReportOptions.Format + ".seq" in step 'Process Step Result', sequence 'SequenceFilePostResultListEntry', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"reportgen_" + RunState.Root.Locals.ReportOptions.Format + ".seq" in step 'Process Step Result', sequence 'ProcessModelPostResultListEntry', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.ReportStyle + ".seq" in step 'Set ReportOptions based on ReportStyle', sequence 'Get Report Options', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Footer', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Header', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Body (Sequence)', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.ReportStyle + ".seq" in step 'Get Report based on ReportStyle', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Set Report Disabled Message', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
RunState.ProcessModelClient in step 'MainSequence Callback', sequence 'Test PEPDC', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\Product\Image\target\Product\Model_A400M.seq'
"reportgen_" + RunState.Root.Locals.ReportOptions.Format + ".seq" in step 'Process Step Result', sequence 'SequenceFilePostResultListEntry', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"reportgen_" + RunState.Root.Locals.ReportOptions.Format + ".seq" in step 'Process Step Result', sequence 'ProcessModelPostResultListEntry', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.ReportStyle + ".seq" in step 'Set ReportOptions based on ReportStyle', sequence 'Get Report Options', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Footer', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Header', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Body (Sequence)', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.ReportStyle + ".seq" in step 'Get Report based on ReportStyle', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Set Report Disabled Message', sequence 'TestReport', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
RunState.ProcessModelClient in step 'MainSequence Callback', sequence 'Test PEPDC', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Model_A400M.seq'
"reportgen_" + Parameters.ReportOptions.Format + ".seq" in step 'Initialize the On-The-Fly Report Generator Object', sequence 'Configure Post Result Callbacks', sequence file 'H:\Sere\07 - Test tools\11 - TestStand\03 - Sources\Product\Cfg\TestStandModels\ModelSupport.seq'
What can I do for them ?
Regards.
