03-04-2010 07:24 AM
I have the TestStand Development System licence (TestStand V4.1).
I would like to deploy my tests. With the deployment tool, I have the possibility to include TestStand engine. The problem is that the deployment package is more than 300 Mb instead of few Mb without TestStand engine. But if I do not include TestStand engine, I have to install the TestStand Development System on PC while it is not a development PC but a PC in charge of executing tests.
What is the solution ?
03-04-2010 07:41 AM
why dont you create a system deployment which is just your TestStand engine and UI and test deployments which contain just your test sequences file, code modules etc.
regards
Ray Farmer
03-05-2010 05:11 AM
I have made 2 deployment package : the firt with the engine, the second with the sequence test.
I install the engine package then the sequence test package.
When I run the sequence, I have this error :
Notice that when I use a full package (engine + sequence test), I do not have this problem.
What can I do ?
Thanks.
03-05-2010 05:18 AM
you need to attach any picture as attachments otherwise no body can see them.
Ray Farmer
03-05-2010 05:49 AM
Sorry 😉
Please see the attached file with the error.
