Developing Programs in TestStand Course CVI Exercises Not Working
Im following the exercises that come with the developing programs in Teststand course. Excercises using LabView all work fine. However none of the CVI exercises work. I can call the functions in the DLL located at C:\Program Files (x86)\National Instruments\Shared\CVI\instr\Driver Simulation\SimulationDriver.dll but all the functions called return 0.
Same thing happens when I create my own DLL and saved it to C:\Exercises\Developing Test\Programs\CVI\Code Modules I see the functions in the drop down menu in the Module tab but again all returned results are 0.
Using Teststand 2021 and CVI 2020
(1,056 Views)
Accepted by topic author antaine_med
Fix for this issue was to ensure that the zip file is unblocked when unzipping the files. Go to zip file properties and check Unblock box.
(1,021 Views)
