Error -17600 Failed to load a required steps associated module
Hi All,
I m facing a strange issue in my Test System. Getting error -17600 when I m running the sequence. In this sequence I m using some of the custom steps. Also I have customized the TestStand OI to integrated with the main application. The error is only when I m running the sequence in customized TestStand OI. But I m able to run the sequence in default TestStand OI developed in LabVIEW. Can anyone suggest a method to identify the issue.
I have verified the adaptor settings ,which configured as  auto detect using vi version.
-Vipin
(995 Views)
Try lowering the path length to your custom OI
(864 Views)
