04-26-2022 12:41 PM
Hi All,
I m facing a strange issue in my Test System. Getting error -17600 when I m running the sequence. In this sequence I m using some of the custom steps. Also I have customized the TestStand OI to integrated with the main application. The error is only when I m running the sequence in customized TestStand OI. But I m able to run the sequence in default TestStand OI developed in LabVIEW. Can anyone suggest a method to identify the issue.
I have verified the adaptor settings ,which configured as auto detect using vi version.
-Vipin
07-19-2022 01:02 PM
Try lowering the path length to your custom OI
