NI TestStand
Error 7 occurred at Invoke Node in New Dist Read Linkages with IMAQdx
I am using LV2017 and TS2016 SP1 on windows 10.
To reduce deployment issues I've created packed libraries for all of the test equipment drivers that I use.  this works great for everything except for a camera driver which has an IMAQdx dependency. On the development PC everything seems to work, but when I try to build the deployment I this error:
Error 7 occurred at Invoke Node in New Dist Read Linkages - TestStand.vi->Dist Read Linkages - TestStand.vi->TestStand - Read Linker Info from File LV 8 or Above.vi->TestStand - Read Linker Info from File LV 8 or Above.vi.ProxyCaller
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Method Name: Linker:Read Info From File
The file at 'C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\vision\driver\IMAQdx.llb\IMAQdx Attribute Type.ctl' was expected to have the qualified name '[NAME OF MY LIB].lvlibp:NI_Vision_Acquisition_Software.lvlib:IMAQdx Attribute Type.ctl', but has the qualified name 'NI_Vision_Acquisition_Software.lvlib:IMAQdx Attribute Type.ctl'.
any tips or suggestions on how to fix this?
am I missing a setting in either the build of the packed library or is it in the deploy project?
(913 Views)
Accepted by topic author Paul.Boucher
OK,   After playing will all the settings that I thought would affect this issue and several I didn't think would.  the issue worked itself out.  unfortunately when I tried backing out the settings to figure out which one fixed the issue, I was able to back out of all of them and it was still fixed.
So I still don't know if the fix was in the labview build, the testStand sequence or the TestStand deploy project
(886 Views)
