Error connecting SQL server with TestStand
Hello all,
I'm trying to process the result of the tests directly to a database in SQL server and I'm having the error that I show in the images. I already tested the connection with the database and all is OK.
I selected this database provider.
Someone can help me with this?
(1,205 Views)
Hi ,
There is DB Viewer in the tools menu.
Open it and connect to the DB with the connection string ( as you say its working fine).
Check for all the tables present.
If the tables are find in SQL server then try with a simple example.
Ravi
(1,180 Views)
Hi Ravi,
Thanks for your help.
I made what you have said and the connection is working correctly, but I don't see any table in the Data Base that I'm connecting. I need to create them, or they are created automatically?
(1,176 Views)
Hi Rodrigues,
The SQL to create the tables are :
C:\Program Files (x86)\National Instruments\TestStand 2022\Components\Models\TestStandModels\Database
(Change path based on the TS installed)
You can run thiD in the DB viewer which support SQL execution.
Ravi
(1,170 Views)
Hi Ravi,
I don't have this path.
Thank you for your help!
(1,119 Views)
