NI TestStand
Exception Error Code -2147024882
during a night long test, my sequence has shown me this pop-up message that I have copied to the attached txt. I translate here the only Italian sentence which is written in the log:
Possible System Error: The available memory resources aren’t enough to complete the operation.
The message occurred during the OTF operation, but I don’t understand why, I mean I have set the OTF option as follow:
  • Processing interval 1.50s
  • Maximum Number of Results 500
  • the Automatically Tune Interval is enabled
And I have never hade problem about memory, instead I have solved them using OTF for long execution.
Is there someone who had the same problem?
Thank you for the attention!
Best Regard,
Zuc
(811 Views)
Though not for OTF but i have seen this error during report generation of large sequences.
The reason is as the error states....the memory keeps on increasing ( check through task manager or other memory usage tools). Even with the OTF i have seen this behaviour.
Is OTF running in parallel to the TestStand execution.Can it run after the execution?
If not Few Things to try :
1) Disable the tracing ( Debugging takes some memory)
2) Remove logging of all unwanted steps ( example in loops, action steps,etc)
3) Unload modules ( if you can in your application ) at different stages if possible. ( This depends on your application architecture).
Ravi
(788 Views)
