02-06-2012 04:56 AM
The simplest solution would be to implement the delay in the SequenceFilePostStepFailure callback. You can use a variable to toogle/configure the waiting in this callback since it is executed for every failing step within the sequence file, not only the looping ones.
If you are concerned that other developer have to implement this functionality but you are unsure if they can work with the callback (e.g. when to set the toggle/config of the variable?), you should create a custom step type incorporating a wait time.
hope this helps,
Norbert
02-06-2012 05:49 AM
Hi Norbert
I like that idea.
And if one puts this expression in the step preexpression:
Step.AsPropertyObject.SetValNumber("Delay",0x1,1)
Creating a new property of the step.
(For reference the first argument is the property name, second argument is the option - in this case "Insert if missing, and the last argument is the value the property is set to.)
Afterwards you could implement this this in the PostStepFailure callback:
This way you probably wouldnt confuse other developers, as the delay would only be active on steps where you create the variable "Delay".
As always good documentation is in order - so other developers dont remove it just because they dont understand what you're trying to do.
08-19-2016 08:31 AM
You can try Runstate.Execution.WaitForEndEx(timeout in milliseconds, ...). It returns in (timeout + 100 milliseconds).
12-26-2017 12:03 PM
that works for me thanks
