04-18-2011 03:19 PM
Is there a way to automatically close the current sequence file when the test finishes executing? I am using TestStand Version 1.0.2
My problem is with Type Conflict errors occuring while running sequence files through a LabView GUI. The user is having to exit all the way out of LabView in order to "unload" the current sequence file types. I am working with code that cannot be modified, so I am wondering if there is a setting somewhere in TestStand that would solve this.
04-19-2011 04:02 PM
The API is found in the TestStand Help. You may be looking for the ApplicationMgr.CloseSequenceFile method call.
04-19-2011 09:37 PM
There was no ApplicationMgr in 1.0.2
