NI TestStand
Exit Sequence after Execution
Is there a way to automatically close the current sequence file when the test finishes executing?  I am using TestStand Version 1.0.2
My problem is with Type Conflict errors occuring while running sequence files through a LabView GUI.  The user is having to exit all the way out of LabView in order to "unload" the current sequence file types.  I am working with code that cannot be modified, so I am wondering if there is a setting somewhere in TestStand that would solve this.
(3,029 Views)
The API is found in the TestStand Help.  You may be looking for the ApplicationMgr.CloseSequenceFile method call.
NI TestStand™ UI Controls API Reference Help>>UI Classes, Properties, Methods, and Events>>Core UI Classes, Properties, Methods, and Events>>ApplicationMgr>>Methods>>CloseSequence File
Jensen
(3,010 Views)
There was no ApplicationMgr in 1.0.2
(3,003 Views)
