Facing timing issue in numerical value Comparison step
Hi All,
I am facing a time issue in the comparison step when I compare 2 numbers. Earlier this step took 0.63 sec for execution, but the same step takes about 10 sec, increasing the total sequence time at a very high level. I tried some settings that can reduce execution time, like disabling the Tracing Enable option, using the execution option is none. But not observing anything. I have attached 1 photo, where the same step takes a different time to execute (when running the same sequence for 2 different times). Can you help me here, what setting I should do in TestStand
(367 Views)
Can you elaborate a bit about the data sources of thise numbers?
(359 Views)
I am using a HiL system. From the system, I am receiving some Analog current/voltage values. When I compare this value with the Constant number and for that comparison step TestStand takes a time.
(345 Views)
So the next logical question: what has changed?
(338 Views)
Since there is no feedback on this thread, I guess your problem is fixed, right?
(278 Views)
Accepted by topic author Oli_Wachno
Guess this issue is solved --> no response
(217 Views)
