12-01-2024 11:50 PM
Hi All,
I am facing a time issue in the comparison step when I compare 2 numbers. Earlier this step took 0.63 sec for execution, but the same step takes about 10 sec, increasing the total sequence time at a very high level. I tried some settings that can reduce execution time, like disabling the Tracing Enable option, using the execution option is none. But not observing anything. I have attached 1 photo, where the same step takes a different time to execute (when running the same sequence for 2 different times). Can you help me here, what setting I should do in TestStand
Solved! Go to Solution.
12-02-2024 12:39 AM
Can you elaborate a bit about the data sources of thise numbers?
12-02-2024 08:04 AM
I am using a HiL system. From the system, I am receiving some Analog current/voltage values. When I compare this value with the Constant number and for that comparison step TestStand takes a time.
12-02-2024 09:07 AM
So the next logical question: what has changed?
12-12-2024 12:42 AM
Since there is no feedback on this thread, I guess your problem is fixed, right?
12-20-2024 01:26 AM
Guess this issue is solved --> no response
