03-10-2009 08:17 AM
Solved! Go to Solution.
03-10-2009 09:11 AM
You can add a precondition for the subsequence
RunState.PreviousStep.Result.Error.Occurred == False
-Vidula
03-10-2009 09:33 AM
03-10-2009 10:02 AM
Try RunState.SequenceFailed. If any of the SequenceCalls fail then this will be set.
Regards
Ray Farmer
03-10-2009 10:07 AM
Or probably better to use
thisContext.SequenceFailed
Regards
Ray Farmer
03-10-2009 10:45 AM
03-10-2009 11:07 AM
02-16-2022 04:20 PM
I am trying to use this expression from a custom report sequence which was built using the Create New Process Model Plug-in, and I get the following Error:
Unknown variable or property name ThisContext.RunState.Main.
Basically I want to append a line at the end of the custom result that displays the overall main test sequences result
