NI TestStand
How can i change AlwaysGotoCleanupOnFailure in CVI
I want to change the "AlwaysGotoCleanupOnFailure" of StationOptions in CVI.
I use TS_API "TS_StationOptionsSetAlwaysGotoCleanupOnFailure(seqContextCVI,&errorInfo,VTRUE);  " to change it. but it;s don't work.
but I use it in LabVIEW,it's OK.
Why?
Teststand 3.5, LabVIEW 8.0, LabWindows\CVI 8.0
(3,391 Views)
Accepted by xhsun826
Hi bisun,
The problem is because you are passing in the Sequence Context to the function, when you should be passing in the StationOptions (just like in LabVIEW).
Here is what the code should look like:
TSObj_Engine myEngine;
TSObj_StationOptions myStationOptions;
TS_SeqContextGetEngine (TS_SeqContext, &errorInfo, &myEngine);
TS_EngineGetStationOptions (myEngine, &errorInfo, &myStationOptions);
TS_StationOptionsSetAlwaysGotoCleanupOnFailure(myStationOptions, &errorInfo, VTRUE);
Jervin Justin
NI TestStand Product Manager
(3,278 Views)
OK, It's work.
Great!
Thanks, Jervin.
(3,260 Views)
