How deep the variable subproperty tree can be?
Quickly,
How many levels of subproperties my cointeiner can have?
Are they any restrictions to it? Size? Name lenght? Number of levels?
(4,175 Views)
There are no fixed limits, though there might be practical ones due to recursive algorithms running out of stack space while trying to traverse a very deep tree, and for lookup strings I believe the maximum size of a BSTR is 2GB so you couldn't have a lookupstring longer than that. If you require a very deep tree I recommend testing the worst case depth you expect to need to support and see if you get any errors. I would expect you to not see any problems except with very deep trees.
Hope this helps,
-Doug
(4,147 Views)
