NI TestStand
How do I make a pass/fail step using only expressions, not a LabVIEW VI?
Hopefully my question title summarized it. I want to make a pass/fail step by evaluating TestStand variable; right now I only know how do to this by making a LabVIEW module.
(3,346 Views)
Accepted by topic author bmihura
You can use a pass/fail step type without a labview adapter (none).
Ensure that you update the boolean Step.Result.PassFail to True for pass and False for fail with your custom expression.
(3,335 Views)
That worked! It took me awhile to remember how to change the adapter from LabVIEW to None (it was the pull-down ring), then your idea worked perfectly.
(3,326 Views)
