01-30-2024 11:12 AM
I have 2 version of LabVIEW installed: 2018 and 2020.
I've already setup LabVIEW 2020 to not update the windows registry. So in windows explorer, when I double click a VI, LabVIEW 2018 gets launched.
But TestStand choose LabVIEW 2020 as the "active LabVIEW version". Why?
How do I make TestStand choose LabVIEW 2018 instead?
01-31-2024 01:51 AM
TestStand chooses the last LabVIEW version which has been started successfully
https://forums.ni.com/t5/LabVIEW/Change-currently-active-LV-version-in-batch-script/td-p/2422008
01-31-2024 01:22 PM
Is there a way to prevent LabVIEW Update that registry key?
02-01-2024 08:21 AM
Not aware of one.
How about starting SeqEdit using a batch file?
Start the appropriate LabVIEW Version first, then SeqEdit?
