NI TestStand
How to Fail String Value Test when the string is found?
I monitor data during a boot up process. If I see a particular string I know the process is corrupt. I want to fail a String Value Test when I see the string. How can I do this in TestStand. We use TestStand 2017.
(784 Views)
Tony
How long does it take the boot process to complete?  If it is quick you could capture the entire boot process into a string (this all depends how you monitor the boot process) and then do a 'Search for String' looking for your match pattern, in your case if it is not found then it would be a pass.
I had done something like this where I captured the boot process by reading a serial port and captured the data in LabVIEW.   Then I used LabVIEW functions to search for a string.   Then used a pass/fail test in TestStand to indicate whether it was found.
PH
(728 Views)
