02-09-2018 09:57 AM
I have a sequence file with several subsequences. I find it hard to understand where am I in the execution because whenever a subsequence is called its contents get displayed and the main sequence disappears from the screen (until the subsequence is running). Once the Subseq is completed TS starts displaying the main sequence again, but then I call another subsequence. So practically I only see the subsequences, but not where is my app overall in the execution.
Is there a way to solve this somehow. Maybe an option to not display the execution of a given subsequence?
thx.
02-09-2018 10:19 AM
For the sequence call steps, select Step Settings>>Properties>>Run Options>>Sequence Call Trace Setting>>Disable tracing in sequence
