How to add a native button to open the Model Options dialog in Configure menu directory?
Hi, Guys:
     I am start a learn from TestStand's example, it is Building a TestStand UI with Native Controls in Modifying User Interface Folder. I try to add some button to open the following dialogs of:
            Station Options
            Search Directories
            Adapters
            Result Processing
      all the buttons are working properly.
      Then I add other button and tried to open Model Options dialog, it is unsuccess.
      my C# code is similar to the following below:
axApplicationMgr. GetCommand(CommandKinds.CommandKind_ConfigureSearchDirectories, 0).Execute(true);   // Open search directory
      I do not know which command of CommandKind can open Model Options dialog.
      Anyone who know this?
      Thank you so much!
(186 Views)
Accepted by Andrew2024
I think this is due to the fact, that the ModelOptions Dialog is implemented in the seq file of the ProcessModel.
In fact, the ModelOptions is a ConfigurationEntyPoint which must be run as a sequence.
Yet you will have to provide parameters...
(173 Views)
The Full-Featured User Interface allows you to configure ModelOption in Editor Mode.
Hav you already checked the solution used there?
(156 Views)
Hi, Oli_Wachno:
    Got it!
    I think that's the reason.
    Thank you so much for letting me know more.
(122 Views)
