01-20-2015 04:16 AM
i used to have Teststand 2010 with lots of StationGlobals.
Now i installed Teststand 2013 but i didnt save my StationGlobals to a file.
But i have a disk-image of the old installation.
The question is now: What files do i have to copy to get my StationGlobals back?
I am using WIndows 7 (old and new system).
Thanks for help
01-20-2015 04:56 AM
TestStand saves the station global variables in the StationGlobals.ini file in the <TestStand Application Data>\Cfg directory.
To get StationGlobals from TestStand 2010, you need to copy StationGlobals.ini from TestStand 2010 and replace StationGlobals.ini in TestStand 2013 directory.
This will overwrite TestStand 2013 StationGlobals.
If you need TestStand 2013 StationGlobals also, you can save them as Local variable of a new sequence and after replacing StationGlobals.ini, you can move these Locals to StationGlobals.
01-20-2015 05:24 AM
Hi
You can also use TestStand Migration Utility Tool to copy the Station Globals from TestStand 2010 to TestStand 2013.
This tool requires TS 2010 and TS 2013 to be installed and TS 2013 to be active version.
Also refer to http://www.ni.com/tutorial/14515/en/#MigratingUserComponentsandSettingsUsingtheMigrationUtility for additional details.
Hope this helps.
Deepak.
