NI TestStand
How to correctly start / shutdown TestStand engine using API?
I try to restart TestStand engine between 2 sequence file executions. Using the TS API from VB .Net.
Steps: Start the TestStand engine -> execute a sequence -> close the engine -> start the engine again -> execute a sequence ....
When I want to start the second execution I get the following error:
Exception thrown: 'System.Runtime.InteropServices.COMException' in RestartEngineTest.exe
Additional information: Operation failed because TestStand Engine was shutdown.
What would be the correct engine restart procedure?
2'nd problem: If I try to force the Garbage Collector
                        'GC.Collect()
                        'GC.WaitForPendingFinalizers()
                        'GC.Collect()
after Engine.Shutdown(True) complete application hangs "inside" the first GC.Collect().
A sample solution is Enclosed.
I start the execution with "myTsEngine.NewExecution"
Upon API.UIMessageCodes.UIMsg_EndExecution I release the sequence file and the model.
Upon API.UIMessageCodes.UIMsg_ShutDownComplete I unload all modules and type palletes and call Shutdown(false) followed on second entry by Shutdown(True)
 Private Sub StartSequenceExecution(nameOfExistingSequenceFile As String)
        Try
            myTsEngine = New API.Engine()
            myTsEngine.LoadTypePaletteFilesEx()
            sequenceFile = myTsEngine.GetSequenceFileEx(nameOfExistingSequenceFile, 107)
            modelSequenceFile = myTsEngine.GetSequenceFileEx("SequentialModel.seq", 107)
            myExecution = myTsEngine.NewExecution(sequenceFile, "Single Pass", modelSequenceFile, False, 0)
        Catch ex As Exception
            Throw New Exception("TestStand Api Problem!" & vbCrLf & ex.Message)
        End Try
    End Sub
    Public Sub TS_UI_Message_Handler(ByVal aktUImessage As NationalInstruments.TestStand.Interop.API.UIMessage) Handles myTsEngine.UIMessageEvent
        Try
            Select Case aktUImessage.Event
                Case Is = API.UIMessageCodes.UIMsg_EndExecution
                    Try
                        If Not sequenceFile Is Nothing Then
                            If sequenceFile.CanUnload Then
                                myTsEngine.ReleaseSequenceFileEx(sequenceFile, 5)     ' UnloadFile, UnloadFileIfModified
                                sequenceFile = Nothing
                            End If
                        End If
                        If Not modelSequenceFile Is Nothing Then
                            If modelSequenceFile.CanUnload Then
                                myTsEngine.ReleaseSequenceFileEx(modelSequenceFile, 5)     ' UnloadFile, UnloadFileIfModified
                                modelSequenceFile = Nothing
                            End If
                        End If
                        myTsEngine.ShutDown(False)
                        ' ignore
                    End Try
                Case Is = API.UIMessageCodes.UIMsg_ShutDownComplete
                    If Not isFinalShutdown Then
                        myExecution = Nothing
                        myTsEngine.UnloadAllModules()
                        myTsEngine.UnloadTypePaletteFiles()
                        'GC.Collect()
                        'GC.Collect()
                        myTsEngine.ShutDown(True) ' 2'nd shutdown
                        isFinalShutdown = True
                    Else
                        myTsEngine = Nothing
                        'GC.Collect()
                        'GC.Collect()
                        MsgBox("First Execution Complete, Starting the second one...", MsgBoxStyle.ApplicationModal Or MsgBoxStyle.Exclamation Or MsgBoxStyle.OkOnly)
                        StartSequenceExecution("Test.seq")
                    End If
                Case Else
                    ' Optional: Do something or not to notify the the user/programmer about unknown messages !
            End Select
            aktUImessage.Acknowledge()
            aktUImessage = Nothing
            MsgBox("UIMessageEvent Error: " & ex.Message, MsgBoxStyle.ApplicationModal Or MsgBoxStyle.Exclamation Or MsgBoxStyle.OkOnly)
        Finally
        End Try
    End Sub
(5,812 Views)
Hi CristianL.,
Just in case, have you seen this Knowledge Base article?
Starting and Shutting Down TestStand from a .NET User Interface
http://zone.ni.com/reference/en-XX/help/370052P-01/tsfundamentals/infotopics/net_ui_start_shutdown/
(5,755 Views)
Yes 🙂
(5,744 Views)
I had a similar problem and this case did help me to solve it.
That's the reason I want to Link my solved case here: 😉
Solved: Re: How to release components correctly via Api (especially Users.ini) in vb.net - NI Commun...
Best Rgds
MAGL21
(2,426 Views)
