NI TestStand
Selecting 1 or more DB to log to at runtime
We have set up a schema in a Database and are happily logging along.
However, we would now like to log to one database every time, and another only when we run specific parts.  In this case they are both MSSSQL databases on the same server, but with different DB names.  I might want to target different servers.
How can we do that?
(1,288 Views)
Have you tried to simply add one more result processing plugin instance and configure it with different names? Then you could use plugin callbacks to enable/disable plugins based on your UUT serial number or something like this.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,238 Views)
We have both configured in the results processing, and it's updating both.  But I am not sure how I can turn one off with the plugin callback as you suggest.  I haven't really played with the DB callback before though.
(1,221 Views)
You can try to use one of those: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsfundamentals/infotopics/pmpclientfilecallback...
Let me know if you will struggle with it. I will prepare a simple example next week.
Michał Bieńkowski
CLA, CTA, CPI
(1,218 Views)
