06-13-2013 10:28 AM
Does anyone know of a way to search steps by name or type, and replace the step itself with a different step? I've been trying to accomplish this with the Find/Replace in Files dialogue, but haven't been able to figure it out. To clarify, my goal is to find all ActiveX controls with a specific name within a single sequence file, and replace them with a similar .NET control. Doing this manually would be very time consuming.
Thanks in advance for any input!
06-14-2013 12:00 PM
Hello TroyS,
There's no pre-made tool that does this in TestStand. However, what you need can be achieved pragmatically.
I found this example that should be helpful if you have TestStand 3.1 or later. You will need to make small changes to replace a ActiveX with a .NET as the example now changes it to None. You can add other steps to make other changes if needed.
Hope this helps.
06-17-2013 08:46 AM
Thanks Tarek. That's very helpful. I'll see what I can do with it.
02-18-2022 05:52 AM
I am facing similar problem, where I want to replace Veristand steps fro GET & SET with ASAM XIL steps. I am on the half way using this https://forums.ni.com/t5/Example-Code/Creating-a-Sequence-File-Iteration-Tool-Replacing-Absolute/ta-... .
I want to know, how replace an individual step ( example of any step type is ok).
