02-05-2025 07:22 PM
I have a sequence file of subsequence and steps. How can I get a list of the name of the sub-sequence(and steps in it) and other steps in text or word format without running the sequence?
I tried "save as" save the sequence file in to a xml file and parse it but no luck.
Thank you so much!
02-06-2025 12:04 AM
might help a bit
02-06-2025 01:11 AM
Even I uncheck all of the options, it still has a lot more than just the step names. Thank you for your help!
02-06-2025 03:39 AM
If you are willing to step into the API, this would be quite easy
02-06-2025 09:59 AM
Do you mean step in the sequence? Please give a little bit more detail or screen shot. Thank you so much!
02-06-2025 10:38 AM
Not sure if all you want is the list of step names as text, but you can just select steps in the sequence editor, hit <Ctrl-C> and then paste in a text editor.
02-06-2025 05:44 PM
Yes, that is kind of what I need. After paste to word, I have to adjust the indentation manually though. That is a small task not worth time to write a script.
Thank you!
02-06-2025 11:23 PM
I meant If you wann use the API....
Yet seems you got a solution
02-06-2025 11:56 PM
Yes, step in the sequence.
From this seq
I want
but after copy paste, I got this which need to manually fix the indentation. It is ok if the sequence is not long and not many layers of indentation, but it is a pain if the sequence is complex.
02-07-2025 01:32 AM
If the build in possiblities are not sufficient for you, you have to implement your own taylored solution using the TestStand API
