NI TestStand
How to implement the sequence view controls in the customized LabVIEW UI
I'd like to use LabVIEW to run the TestStand Sequence, and show the execution windows in the UI.(something llike the attached image)
I followed my senior's method : connected the sequence view controls into the TestStand UI Execution View Manager as objects.
Then use the register event callback to build a callback VI.
The callback VI is checking which the RunState of the Execution Manager is stopped and assigning the execution to that Execution Manager.
Though it works, but really confuses me, needless to say to you all.
Could someone give me some suggestion how to show the execution windows in the LabVIEW UI? I'll appreciate your help.
(5,326 Views)
Accepted by topic author William1225
It's too complicated to answer your question in simple words.
Please take a detail look at the following links. It comes with some basic concepts and tutorials regarding how to use TestStand UI in LabVIEW.
https://www.ni.com/en/support/documentation/supplemental/08/teststand-user-interface-development-bes...
https://www.ni.com/en/support/documentation/supplemental/12/working-with-the-teststand-simple-user-i...
(5,292 Views)
Hi, Ting
Thanks to your direction, I'll study those material.
Are you taiwanese? Do we know each other 🙂
(5,247 Views)
Hi William,
Yes, I am the Ting that you know.
We have to reply the questions on this forum too.
So it would be the same if you mail us your question using support.taiwan@ni.com.
Thank you
Ting
(5,244 Views)
Hi William,
Thank you
Ting
(5,244 Views)
great that's what i want.
(4,835 Views)
