11-22-2006 10:17 PM
11-27-2006 05:52 PM
Hey Toko,
To do this, you would need to modify the xsl, which would require a pretty strong XML background. The actual process of adding a column to the table through the xsl is known to be very complicated. Perhaps somebody has done this before, but it is not actually supported through National Instruments.
11-28-2006 02:45 AM
05-31-2016 10:10 PM
i am doing this recetently,
found a help:
titile is :Adding Columns and Rows to an ATML Test Results 6.01 or 5.0 Report
follow it ,i can add cloumn and values to the report,but i cannot find the way how to pass locals、parameters to the report.
the help pass the value "@testReferenceID" to the report ,how can i modify to my parameter ,ie ,an step parameter ?
<td><xsl:value-of select="@testReferenceID"/></td>
waiting for help,thanks
06-01-2016 07:51 PM
maybe i did not descripted very clear.
so i add a picture ,wish to help understand my question.
thank you
@Col1、@Col2 is wrong parameter,how to pass correct parameter? thanks.
06-02-2016 04:23 AM - edited 06-02-2016 04:24 AM
Boguang,
When you ran the sequence, did Col1 and Col2 return anything in TestStand?
Here's something that I think you might find useful http://www.ni.com/white-paper/8289/en/
06-02-2016 05:45 AM
thanks for your reply,AYPYoo
i have read the article ,but still cannot OK.
maybe should know XPATH,but how teststand pass local variables to ATML report?
please refer to the link below:
Adding Columns and Rows to ATML Test Results 5.0 Reports
06-02-2016 05:48 AM
my question is how to pass teststand local variables or parameters to the report table column Col1 or Col2?
what is the relationship between with Col1 and local variables
06-08-2016 04:40 AM
What you're trying to do is very complicated as it requires you to have a deep understanding on XSL syntax.
Perhaps you can achieve your ultimate goal by checking the Log checkbox (in Module tab) of your local variable and parameters?
06-11-2016 09:55 PM
thanks for you reply.
xsl is too complicated.
my question is : what is the relation between xsl file's parameter and teststand's parameter
