04-29-2022 04:09 AM - edited 04-29-2022 04:10 AM
Hello all,
At the moment, when I execute a test in TestStand, I obtain a report in .html format. But I would like to have the same report in .html with the expand/collapse option activated, what it is only available in .xml format (in this option, I can select the style sheet as expand.xsl).
When I select the report format in .xml, I have seen that TestStand generates a temporary report in .html with the expand/collapse option activated (this is just what I want).
Does anyone know how I can save this temporary result in .html with the expand/collapse activated instead of the .xml format?
Or how can I directly obtain a .html report with the expand/collapse option activated?
Thank you in advance!
05-11-2022 01:46 AM
No one? 😞
02-14-2024 07:34 PM
Hello there,
You can try transforming the XML file to HTML if the features you need are present only in the XML file. Here is an article that can help you with that:
Transforming XML Content to HTML Output - NI
