NI TestStand
How to share .NET object reference between TestStand and Labview (TestStand User interface)
I'm using Labview TestStand user interface and Teststand. In TS I open .NET assembly reference - it is stored in teststand sequence as Object reference. Now, I want to get this reference into Labivew User Interface.
I tried to send Object reference from TS to LVusing UIMessages but It does not work. Please help
(1,036 Views)
In your case, probably the simplest method would be to use "Thread" property of UIMessage and call "GetSequenceContext" method on it.
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(1,018 Views)
Thank you for answer. Can you give me some additional information ? Cannot understand from what you wrote.
(999 Views)
