How to show socket number in UI ListBox Control?
I want to display the socket number in the Execution Listbox Control. I use DisplayExpression method, set the input as "%TestSocketIndex%", but it doesn't work. This methond works fine if I connect the UI Combobox Control to the ExecutionViewMgr.ConnectExecutionList.
(4,678 Views)
Accepted by wellsc
Hey wellsc,
I have looked into this issue and ran into the same issue you described. I filed CAR 482840 for a developer to investigate the issue further. Unfortunately, the only workarounds I can immediately think of would be to either use a ComboBox, or to implement the desired functionality using a native LabVIEW ListBox.
Let us know if there is anything we can do to help, or if you have any further questions about how to implement one of the workarounds. You can always use that CAR number to check in on the status of the issue, as well.
(4,664 Views)
Hi Daniel,
Thanks very much for your replay. I understand the situation now.
(4,604 Views)
Hello Daniel,
are there any updates according the CAR?
How to implement the workaround using a native LabVIEW ListBox?
I don't want to use the TestStand UI ComboBox Control cause of the appearance.
Best regards
Thomas
(3,612 Views)
