01-26-2022 08:05 AM
Hello all
I am new to Test Stand.
For some odd reason when I try to open the configure -> model options.
I get the message shown in the attached screen shot.
After pressing "Ok" with or without the check box. nothing happens.
What can I do.
Thanks!
Gil,
01-26-2022 08:43 AM
Hi Gil,
That is the model options dialog that is shown for the Sequential process model. If you want to configure the model options for the Batch model, you will need to either change the process model for Station or for the sequence file.
Anand Jain
NI
01-26-2022 09:22 AM
How Do I change the process model, I cannot access the menu option..
02-03-2022 01:13 AM
Anyone?
02-03-2022 04:40 AM
Can you please explain as to what you want to acheive.
Ravi
02-03-2022 07:47 AM
Hello Ravi.
I am trying to change beck the sequence setting. and change the number of threads or the operation mode.
Right now, I cannot change it.
Thanks!
02-03-2022 08:36 AM
Can you post a screenshot of the UI that you are using? Is it the default shipping NI User Interface or something custom?
In the User Interface do you have a menu called Configure->Station Options?
That menu option should pull up a dialog shown below. In that dialog in the Model tab you can change the model used for the station to Batch process model.
Once the station model is set to batch, configure model options should allow you to change the number of settings for the batch.
Hope this helps.
-Anand
02-07-2022 07:10 AM
Thanks!
That solved the issue.
Gil,
