10-30-2013 08:59 AM - edited 10-30-2013 09:21 AM
Hi guys, I'm new of Teststand and I'm trying to learn.
Well I did an one step application like the one attached.
I'm a little bit confused on how to set the input variables. I want that taststand ask me to set them.
Another question is how can I see the result of my test in the final report? I want to see the result of the sum and of the product. Can you help me?
Thank you
10-30-2013 10:06 AM
in particular about the fact that I want to see the outputs on the report I'm following these steps as I have read them in the guide:
On the Properties tab of the Step Settings pane, complete the following steps to add the
numeric array and other values to the report.
a. Click Additional Results to show the Additional Results panel.
b. Place a checkmark in the measurements [Out] parameter checkbox to log the output
value of the parameter.
But it doesn't work........
11-01-2013 05:48 PM
Look at the changes I've made to your VI and sequence. Is this what you are trying to achieve?
11-04-2013 01:29 AM
Hi there, thank you for your help. I found out the error I did few days ago but I didn't find the message here on the forum to update it.
By the way again thank you.
