Low GDI object for NI teststand 2020 SP1 32bit
NI products: Teststand 2020 32bit, LabVIEW 2020 32bit Operating system: Windows 11 64bit Problem: When tried to the the analysis of sequences the testand gives an error of low GDI object. we have more than 1000 sequences currently. after the error pops up it will not allows to take any further actions like open a new sequnce. Error: Can't create window, GDI or USER resources available for this process are too low. This error not observed in the teststand 2014 32bit which we are currently using. Open NI testsnd 2020 SP1 32bit In Main sequence do the anyalysis of all sequences all together perform above step 2 to 3 times and the error pop up will appear This is not allowing to execute the sequnces.
(934 Views)
Can you install TS 2020 f1 patch to check if it resolves your issue?
Anand Jain
NI
(892 Views)
Yes, I have already installed f1 patch, the issue still exists.
(882 Views)
