02-22-2024 11:38 AM
Hello everyone, i'm new to Teststand, and in my ATE Project, i have three variables from getting data from UUT: 1,2,3; and after a pass/fail step that if these three variables are equals to A,B,C the result is pass. This is the idea, and the test pass, but on report the result is: " additional result, fail".
The expression in Data Source of the Pass/Fail step is:
(var1 == "A") && (var2 == "B") && (var3 == "C")
Is it correct to put this expression in Data Source?
Where i' m wrong?
Thank you in advance, Giorgio
02-22-2024 11:59 AM
Put your Data Source back to default: Step.Result.PassFail
Then set your Post Expression to Step.Result.PassFail = (var1 == "A") && (var2 == "B") && (var3 == "C")
02-23-2024 08:43 AM
