NI-488 2.2.6 vs NI-488 2.2.7
I am using NI-488 version 2.2.6 and older on my PC, mostly with Visual Basic Test programs.
Since the installation of TestStand 4.2 and LabView 2 days ago, the NI-488 is now updated with version 2.2.7.
Now when I execute Visual Basic programs accessing GPIB, my computer and Windows XP crash, giving a blue screen with the following info:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time, ..........
Check to make sure ..............
If the problem continue, .......
Technical information:
** Stop: 0x00000050 (0xFFFFFFFD, ox00000008, 0xFFFFFFFD,0x00000000)
Beginning dump of physical memory.....
De-installing and re-installing of NI-488 drivers gives no correction.
Any corrective action (or application note) is available?
Thanks.
(3,121 Views)
After investigation, the crash is due not the NI-488 driver, but to the NI-DAQ 7.4.4 (legacy) driver. We have PCI-DIO-96 cards on our PC, with driver 6.9.3. When TestStand 4.2 and LabView was installed, the 6.9.3 driver was not properly removed, and there was a confilct with version 7.4.4.
By doing a repair on the NI-DAQ 7.4.4, the driver 6.9.3 was then removed, 7.4.4 was repaired, and the crash problem was then solved.
(3,104 Views)
