05-26-2016 01:29 PM
I want to use the NI-Scope Soft Front Panel to Set up my NI PXIe Scope/Digitizer (5160), then save the configuration to a file (looks like the file is saved in ".h5" format). Then I want to load that configuration in a TestStand Sequence. The Soft Front Panel has a "Load Configuration" (see attached image
s) option that lets a user point to that .h5 file to load the configuration to the instrument. Does anyone know where the VI for this is so I can call it in my teststand sequence? If not, is there a solution to load a .h5 file to an instrument in TestStand?
Thanks!
05-27-2016 03:40 PM
Is there a specific reason you need to do it this way or could you not just create a LabVIEW module with your desired configuration?
06-03-2016 10:30 AM
The configuration is not known. A user will need to load in the config file at run-time.
06-06-2016 10:11 AM
Hi Brandon, it looks like the shipping VIs for the soft front panels are only executable, non-editable versions. If you would like to create your own VI to parse through an .h5 file, there are plenty of examples available online for this. I am linking one I found on google below.
