NI TestStand
NI modules for Flo-meters
i need a 0-5v sensing module and a 0-5v supply module for a flo-meter. which two NI modules would i need for LabView
Message 1 of 9
(1,548 Views)
So you want to generate 0-5V analog voltage and also measure a 0-5V analog voltage?
Are these going to be static values or a continuously varying?
Santhosh
Soliton Technologies
Message 2 of 9
(1,530 Views)
yes, and it will be continuously varying
Message 3 of 9
(1,524 Views)
the ni's should be a input and output
Message 4 of 9
(1,523 Views)
How fast will it be varying? do you know the maximum frequency of the signal you will be generating or acquiring?
Santhosh
Message 5 of 9
(1,515 Views)
we are not sure about how fast it will be varying and the maximum frequency yet. All we have so far is the electrical specifications
Message 6 of 9
(1,505 Views)
And do you have any accuracy requirements for the Analog Input and Output? any budget?
I ask these because the DAQ recommendation varies by the specs and cost.
The low-cost DAQs are "low-cost" because they have hardware limitations.
https://www.ni.com/en/shop/data-acquisition/entry-level-usb-daq.html
The cheapest DAQ with AI and AO is USB-6001
Santhosh
Message 7 of 9
(1,491 Views)
no accuracy requirements yet, but we dont have a budget. The USB ni would not work because we would need chassy for powering it and for the supply we need it to be a variable voltage output.
Message 8 of 9
(1,487 Views)
So, you have a long way to go.
Can you provide all the details at once instead of bits and pieces like this?
Santhosh
Message 9 of 9
(1,455 Views)
