02-19-2009 05:56 AM
I have a problem in TestSTand 4.1 with using the NewSubProperty API call on a remote system. I use it to create a StationGlobal on the fly having a named type. The TestStand configuration is identical on both machines and it includes the TypePalette with the named type in question.
When executing the sequence locally on the remote computer (using the standard Operator Interface), it works. When executing it under the remote engine, it gives an error that the type is not known. Other NewSubProperty calls using built-in types work fine.
Any ideas?
Best regards
Peter
Solved! Go to Solution.
02-19-2009 10:16 AM
02-23-2009 09:41 AM
