NI TestStand
OMICRON 256+ configure V-Fault
Hello
I created a short test, only to test communication with OMICRON 256. See Capture.PNG
I can see that the Init CMC connection step pass gets done with no errors when I open it in Labview and run with lightbulb.
But when the COnfigure CMC VFault step is done, then I get an error. See Error.PNG
What might be the problem? Help will be appreciated.
Teststand: 2016 SP1
Labview 2016
Marinus
(1,096 Views)
Thank you people
I found the problem. I didn't specify the VIs in and Out variables.
Marinus
(1,056 Views)
Can you say which instrument Library you used is it with ActiveX control (Test universe)or direct communication with instrument
(822 Views)
