10-25-2023 05:23 AM
We are porting our system to TestStand 2023 Q4 and we tried to configure our ResultsProcessing-configuration.
We have made some customizations to this and got a crash in the Offline Processing Utility UI, we did some modifications and tried some more but still crash.
Anyway, we then decided to remove all our customizations and and start from scratch instead, and we still get a crash.
How to reproduce the issue we get:
Remove the ResultProcessing.cfg file located in: C:\ProgramData\National Instruments\TestStand 2023 (32-bit)\Cfg\ModelPlugins
Open SequenceEditor -> Configure -> ResultsProcessing... (a new default file will be created).
Close SequenceEditor
Open OfflineProcessingUtility -> Click Pause
Click Configure -> Click Cancel
Click "Play" and then ORPU says: "One or more errors have occurred. Please save your work and restart the application".
If open ORPU again, the profile is set to "Pause" and I can enable it again with "Play".
But I cannot do any configurations to the file from here.
10-26-2023 02:51 PM
Hi Isabel,
Thank you for reporting the issue. It is been tracked with this id 2563163.
To workaround the problem, do the following
The config file is redirecting the stdole assembly to version 17.0.0.0 which is not installed.
Jose Hernandez
10-27-2023 01:18 AM
Thank you for the reply!
The workaround is working for me! 👍
Best Regards,
Isabel
01-29-2024 09:14 AM
Hi Jose,
thanks for the workaround, but do you know why this happens? We are also updating our systems to TestStand 2023 Q4 and get the same error on all of our systems. Is there a way to avoid ther error? I don´t want applie your workaround to all of our systems.
Thanks for your help.
Regards.
sneb
