01-24-2018 07:48 AM
I have a pass/fail test with has an "error out" and a "PassFail flag" and a "Report text" output. I'd like to differentiate between an error (eg: a file the test wants to open can not be found) and an actual failure (eg: measurements are not within the limits)
So I have set the Step.Result.Error, Step.Result.ReportText and Step.Result.PassFail variables to my output. If the test fails it jumps to the Cleanup as I have set. If the step outputs an error then it continues the execution (I'd like it to go to the cleanup on an error as well)
How should I handle this?
thx!
01-24-2018 07:54 AM
Check your station options for error handling. I assume that your station is configured to "Ignore". Default setting is "Show Dialog".
01-24-2018 09:16 AM
Yeap, you are right, it was set to ignore. Thanks.
