05-27-2015 08:28 AM
Hello. I'm really new at using TestStand and I'm trying to pass the UUT serial number to a LabView vi. I tried using Runstate.Root.Locals.UUT.SerialNumber as the value to pass but it didn't work. It seemed not to like UUT. Any suggestion would be helpful. Thanks in advance.
05-27-2015 09:28 AM
It will show in read and give an evaluation warining but it should work at run time.
11-23-2017 08:39 AM
Getting the same thing.
11-27-2017 10:49 AM
I would suggest making a new forum post to help more people see your post.
01-18-2018 03:44 AM
hi i have probleme in my code too
i want to put the serial number from teststand to stieng in labview.
01-18-2018 04:53 AM
I used a 2 step process. I'm checking to make sure a serial number is entered (not an empty string) and pass the string to a local variable. I can then pass the local variable to LabVIEW.
