Passing values from CVI dll to TestStand gives wrong values
Initially I wanted to pass an array of booleans from CVI to TestStand.  I read that this was not possible because you cannot set Boolean as a parameter.
So I declared it as unsigned intin CVI.
Strangely enough, TestStand does receive it as an arrayof Booleans.  However the values are still wrong.  I wonder if it actually is possible to pass an array of Booleans.
Using TestStand 3.1 and CVI ver 7.1 (no impact)
Here is how I declare the parameters in CVI:
void __declspec(dllexport) __stdcall MemTest
    CAObjHandle     thisContext,
    unsigned char *    apbResult,
    int             alComport,
    int                alSocketNum,
    UINT32            aulHostAddr,
    BOOL        *    apbTestOutcome,
    UINT32             testSize,
    UINT32          startAddress
The other functions within CVI use an array of booleans.
Here is how I declare the parameters in TestStand:
Here are the results I get.  They should match...
The obvious question is:
How do I get the results in TestStand to match those from CVI?
The printout >>  no. 1 Passed << etc..  are the values of the array apbResult in CVI.  bSippResuls should match.
Message Edited by Ray.R on 10-16-2009 10:41 AM
(3,183 Views)
Ray,
Try this:
void __declspec(dllexport) GetResults(unsigned char arg1[16])
 //Insert function body here.
 arg1[0] = (unsigned char)0;
 arg1[1] = (unsigned char)1;
 arg1[2] = (unsigned char)0;
 arg1[3] = (unsigned char)1;
 arg1[4] = (unsigned char)1;
 arg1[5] = (unsigned char)0;
 arg1[6] = (unsigned char)1;
 arg1[7] = (unsigned char)1;
 arg1[8] = (unsigned char)1;
 arg1[9] = (unsigned char)0;
 arg1[10] = (unsigned char)1;
 arg1[11] = (unsigned char)1;
 arg1[12] = (unsigned char)1;
 arg1[13] = (unsigned char)1;
 arg1[14] = (unsigned char)0;
 arg1[15] = (unsigned char)1;
Regards
Ray
Regards
Ray Farmer
(3,174 Views)
