10-16-2009 09:38 AM - edited 10-16-2009 09:41 AM
Initially I wanted to pass an array of booleans from CVI to TestStand. I read that this was not possible because you cannot set Boolean as a parameter.
So I declared it as unsigned intin CVI.
Strangely enough, TestStand does receive it as an arrayof Booleans. However the values are still wrong. I wonder if it actually is possible to pass an array of Booleans.
Using TestStand 3.1 and CVI ver 7.1 (no impact)
Here is how I declare the parameters in CVI:
void __declspec(dllexport) __stdcall MemTest
CAObjHandle thisContext,
unsigned char * apbResult,
int alComport,
int alSocketNum,
UINT32 aulHostAddr,
BOOL * apbTestOutcome,
UINT32 testSize,
UINT32 startAddress
The other functions within CVI use an array of booleans.
Here is how I declare the parameters in TestStand:
Here are the results I get. They should match...
The obvious question is:
How do I get the results in TestStand to match those from CVI?
The printout >> no. 1 Passed << etc.. are the values of the array apbResult in CVI. bSippResuls should match.
10-16-2009 02:31 PM
Ray,
Try this:
void __declspec(dllexport) GetResults(unsigned char arg1[16])
//Insert function body here.
arg1[0] = (unsigned char)0;
arg1[1] = (unsigned char)1;
arg1[2] = (unsigned char)0;
arg1[3] = (unsigned char)1;
arg1[4] = (unsigned char)1;
arg1[5] = (unsigned char)0;
arg1[6] = (unsigned char)1;
arg1[7] = (unsigned char)1;
arg1[8] = (unsigned char)1;
arg1[9] = (unsigned char)0;
arg1[10] = (unsigned char)1;
arg1[11] = (unsigned char)1;
arg1[12] = (unsigned char)1;
arg1[13] = (unsigned char)1;
arg1[14] = (unsigned char)0;
arg1[15] = (unsigned char)1;
Regards
Ray
