10-28-2014 04:09 AM
hi,
a. i am using sequential process model
1. I am using my motor unload & all stop steps in the callback PostUUTLoop (i need it this way) in the cleanup steptype
2. if there is some system error comm. error etc the teststand engine goes till postuut callback but end the execution there
3. i have also disabled the "Handle Termination" step (looking in the sequentialmodel.seq)
why is the seq ending abrubtly
10-28-2014 04:34 AM
one more info
my cleanup steps in PostUUT callback generate error messages
10-28-2014 05:28 AM
What have you configured for "runtime error behavior"?
It sounds like you are aborting the execution!
Norbert
10-28-2014 11:31 AM
thanks Norbert,
The answer to your question is "On Runtime Error" = Show Dialog
What I am not able to get is that if there is an erorr in PreUUTLoop or Post UUTLoop the next step is mostly Termination
the sequence Pointer does not go throuh all the cleanup steps after that.
I had expected the Pointer to go through the Cleanup Group of PostUUTLoop
My issue is I am using the Device-Initialization & Device De-Init steps in PreUUTLoop & PostUUTLoop respectively.
and any error inbetwen aborts the execution
Also I found that the execution Jumps to " ProcessCleanup" call back, If I select "On Runtime Error" = Show Dialog or Run Cleanup
regards
Akshay
10-29-2014 03:42 AM
Akshay,
depending where the runtime error occurred, the "run cleanup" does exactly what it tells: It only executes "Cleanup" steps. If the error occurred somewhere in the process model before PostUUTLoop, this callback will not get called as it isn't part of the cleanup steps of the execution entry point.
There is one exception where a runtime error might occur which does not (using the "run cleanup" option) call solely the cleanup stepgroup steps: If the error occurs in the MainSequence. In this case, the process model will continue normally, otherwise, you wouldnt get a report in case of an error in the MainSequence (and subsequences).
For all other instances where errors occur the "run cleanup" option makes sure that the complete callstack (including the toplevel process model) will only execute steps from the cleanup stepgroup.
Norbert
