PreUUTLoop equivalent for parallel model
I am building a test sequence to test two UUTs in parallel, on a station where some of the equipment will be shared.  I want to initialize all the equipment BEFORE the exectuion of the tests begin, and even more specifically before the PreUUT step of each individual socket execution.
It made sense to put my "Initialize Equipment" step into the "PreUUTLoop" sequence callback in an original design that used the sequential model. It only needs to be done once.
Is there a similiar sequence callback in the parallel model into which I can move the "Initialize Equipment" step?
(3,132 Views)
Accepted by mike_22
I put in the SequenceFileLoad callback.
(3,131 Views)
The SequenceFileLoad callback has the advantage of only being called once.
However, for reference, I want to note that there are also ProcessSetup and ProcessCleanup cleanup callbacks that are respectively called before and after TestUUTs and Single Pass for all NI models.
(3,115 Views)
