12-22-2014 04:41 PM
I have a UI where I can open sequence files to view and run. The UI was written in c#. Each of the steps in the sequence files call into .net modules also. Each call has three parameters. One the paramters is the name of a file that I want to open from the UI using notepad is the user wishes.
How do I get access to the parameter values of the step module programatically?
I have access to the step module object using the fololowing line of code:
Module myModule = this.seqFileViewMgr.SelectedSteps[0].Module;
Once I have the module object, I cannot seem to find a way to get an array of the paramter values via the TestStand API.
Does anyone know how this is done?
Thanks and regards,
Sean
12-23-2014 02:37 PM
Hello spthornton,
Please view the following link:
http://digital.ni.com/public.nsf/allkb/129785F0AFABB90A8625686E005AE407
I hope this helps. Happy holidays!
01-02-2015 09:50 AM
DotNetModule dotNetModule = myModule as DotNetModule;
Hope this helps,
-Doug
